4bbl carb
    4bbl carb
    Is throwing a 4bbl carb on my Lincoln going to be worth the loss of mileage for the performance I gain? What CFM should I go for also if I do?
    why would it lose mpg?
      Use a vacuum secondary carb.
      1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
        stock 351? I wouldn't go over a 600 cfm carb, probably 500-550 should do fine. The mid 80s 351 4bbl trucks actually had a 390 cfm carb on them.
        Keep out of the secondaries and it won't cost you any fuel economy if the carb is tuned correctly.
          what motor?
          a 670 street avenger would probably be a good choice
            Pray to God that a certain someone doesn't see this.
            I'd skip Edelbrock's offerings, and grab a Holley. Or, if you have the money, and can find one, a BG 525 Road Demon.
              I thought the whole point of having 4bbls was to allow more gas and air to be injected.
              engines a 351W
              edit: nvm I understand the fuel economy part.
                Yeah a stock 351 with between a 500-600 cfm vac. secondary carb will do you just fine. I myself like edelbrock cabs just because of the tuning simplicity. You can get more out of a holley if you all ways want to mess with it. But that might just be the experience I've had with them.
                  Edelbrock bad! Holley smash Edelbrock!
                    I had a feeling you wouldn't like that.:cowboy:
                      Well, if you have an Edelbrock, run it.
                        edelbrock wont be bad on a stock 351, I would go 750 in an edelbrock though
                          aiiiiight. If i want to go over 600cfm i guess it wouldnt make a difference unless i got new heads and all that, am i correct?
                            You trying to drown it?
                              imho its stupid to run anything under 600cfm
