what can be wrong?
    what can be wrong?
    the lincolns carb doesent squirt gas in the barrels when you pump the pedal. i put a new accelerator pump on and new air horn that doesent have the port for the charcole canister. the old pump seased and i thought that was the prob but its not. the car runs great when u dump gas down the carb but when you wanna give it gas, it wants to quit. whats wrong here? :drug: lol
    are you getting gas into the carb?
      for some reason the cab is working now how it should. but i found another thing, the vac hose goin to the ditributor was clogged, so now it runs how it should except it still trys to cut out sometimes if i hit the gas quickly...and oh ya, this is a 351W.
        and i forgot, i have a set of plugs for my merc that are for a 302, will they work on the 351?
          apsrk plugs? they should work.
            The new air horn doesnt have the nipple for the fuel bowl vent.
            This could cause a problem....
              if the car was sitting for some time, there could be dirt from bug nests etc in the carb.......confirm that you have fuel pressure first, then clean out the carb
                :stupid:
                my vote is crap in the squirter jets or crud jamming the checkball. since you have the kit, just give it a good overhaul and a full cleaning.
                  why is this so?, i took it off a 1980 F-250 so it must of been stock equipment
                    now it seems to quit when you hit the gas very fast and bogs out when accerlerating in gear and out of gear. :drug:
                      Do like Thain suggested-check the acc pump check ball in the booster tower, make sure it still has the weight on top of it. The weight will look like a pin. It sits on top of the check ball.
                        do you have the float set correctly?
                          i never touched the float settings.
