the lincolns carb doesent squirt gas in the barrels when you pump the pedal. i put a new accelerator pump on and new air horn that doesent have the port for the charcole canister. the old pump seased and i thought that was the prob but its not. the car runs great when u dump gas down the carb but when you wanna give it gas, it wants to quit. whats wrong here? :drug: lol
what can be wrong?
what can be wrong?
2011 Ford Crown Victoria Police Interceptor (Down with O.P.P)Tags: None
are you getting gas into the carb?http://secondhandracing.com/Home.aspx
for some reason the cab is working now how it should. but i found another thing, the vac hose goin to the ditributor was clogged, so now it runs how it should except it still trys to cut out sometimes if i hit the gas quickly...and oh ya, this is a 351W.
and i forgot, i have a set of plugs for my merc that are for a 302, will they work on the 351?
apsrk plugs? they should work.http://secondhandracing.com/Home.aspx
if the car was sitting for some time, there could be dirt from bug nests etc in the carb.......confirm that you have fuel pressure first, then clean out the carb
:stupid:
my vote is crap in the squirter jets or crud jamming the checkball. since you have the kit, just give it a good overhaul and a full cleaning.86 Lincoln Town Car (Galactica).
Originally posted by grand_marquis_gtThe new air horn doesnt have the nipple for the fuel bowl vent.
This could cause a problem....
now it seems to quit when you hit the gas very fast and bogs out when accerlerating in gear and out of gear. :drug:
do you have the float set correctly?
i never touched the float settings.
