hey all i put a 2.25 in/out Flowmaster super 40 on my lincoln and it wasnt louder than stock really. Is it because of the muffer, the fact that it is a single exhaust, or is it likely the manifolds(which need to be swapped to headers). any help is great!
89 lincoln towncar exhaust not loud
by any chance are they the delta series? i heard a 10sec mustang the other day that was barely louder than stock because of the Flowmaster deltas.http://secondhandracing.com/Home.aspx
89 town car....
you have 4 catalytic converters under there. punch em out and it will be louder. upgrade to an h-pipe and another flow 40 and it will definitly be louder. the stock manifolds really have no bearing on noise. i drove my 86 vic with punched cats, and straight pipes and it was loud as can be. i was running the stock manifolds as well.Save a seal, club a liberal.
Track down a link to one of my videos and you can see what a towncar will sound like with shorty headers, 2.5" offroad h-pipe and flowmaster 40 series
'80 Town Coupé
its the cats and the single. i might have a stock towncar H soon but you'll have to figure out how to get it to you. it wont be for a while as i'm laid up with a fucked up hand and no money.86 Lincoln Town Car (Galactica).
ok, I got bored enough to grab the links to the vids
~8mb burnout clip
14mb cold idle and revving clip
'80 Town Coupé
I ran with with punched out cats and no pipes and thought it was fairly quiet.1989 Grand Marquis LS
thats the way i want my towncar to sound like phayzer, do you have any cats on there? I dont know how I'd pass inspection with no cats (NC) can I gut the cats or take off 1 pair and make it louder?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
an off road pipe means no cats at all. from the headers to the mufflers is a 2.5" H-pipe. I've heard of people that have passed without cats, its all in how its tuned i guess. If its only a visual inspection, you can always try welding the cat heat shields over the pipe in place fof where the cats should be
'80 Town Coupé
mid pipes are different, but the mufflers should stay in the same spot if the midpipes are bent to allow for it. ask scott how he did his, or ask me once i get around to doing it. the mustang offroad pipes also require changing to headers because the flanges are different on the header vs the manifolds.86 Lincoln Town Car (Galactica).
