I have a 93 mustang lx 5.0 engine that i am putting 83 gm accessories on to put in my 83 grand marquis well long story short. I have a lx long block with a 83 gm timing cover and 83 gm water pump on it so far. ------I forgot which bolts go where on the timing/water pump. -- Thank you everyone that has helped me so far and will/might in the future.
83 gm waterpump/timing cover bolts
You're going to have to keep trying until all of the bolts go in. You may have to move them around once you get all of the accessories on the water pump. some are also longer than others so it's time consuming but you'll figure it out. And welcome to GMN,
been there, wont do that again.. I had to do what vicky said and it wasn't fun.Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
yep, move them around till they look right. Pushed in but not threaded in, they should all be roughly the same distance away from the face of the pump. The two longest ones go through to the water jacket on the outer edges. The one without the stud goes near the connection to the lower rad hose.86 Lincoln Town Car (Galactica).
If they're in bad shape, get new ones. Also, use a good coating of antiseize one the long ones where they go into the water jacket. Its a real pain in the ass when those break.86 Lincoln Town Car (Galactica).
i have gotten the water pump bolt sets from napa for around 25 dollars......clean your originals up with a wire brush, if the shoulders are pitted real bad, i would replace them.....it is normal for them to have alot of surface rust on them
