Car cuttin off again when i turn on A/C
    I think i might just need to turn up my idle a lil bit more to compensate for when the compressor comes on. Not all the time it will cut off but some of the time. Any one else ever have this problem or can give me a lil advice it would be appreiated.
    The Best
    there is supposed to be a relay that will raise the idle when the air kicks on. yours might be going bad.
      where would that relay be located at on a CFi?
      The Best
        IIRC right on the throttle linkage on the throttle body, it's a solenoid that sits right by the idle adjustment.
          If anyone can take a picture of this solenoid or have a drawing of it please post for me so i can replace this solenoid.. Thanks alot..
          Nate
          The Best
            how old is your comressor? the clutch/pulley might be locking up
              Compressor is brand new. Thanks for the help i didnt know the solenoid was the one that we wired up to the switch.. So all i have to do is just turn it on when i turn on the AC..
              The Best
                i got rid of my A/C cuz they will never work good for ever
                  Well i went out last nite and i turned left the switch on that i wired to turn on that solenoid and as long as i had that on with the AC runnin i had no problems..So i just gotta make sure to turn teh switch on when i am runnin my AC. But when im not teh car runs fine with out that switch.
                  The Best
