Hi
I'm thinking my O2 sensor is bad and I was thinking with the short distance I usually drive I would greatly benefit from a heated O2 sensor. I've ran a wire from my current sensor inside the car and I'm going to hook my dmm up to it later today so I can monitor the output voltage to make sure it is not sending proper signals.
Has anyone done this conversion? If so any tips? It should be a pretty easy swap.
My thought is to connect the heater either to a switch on the dash, a timer that automatically comes on when the car is started, or a combination of the switch and the timer to make sure I don't forget to turn the switch back off. I suppose there is a fourth option if you assume that it will be up to temperature at the same time the engine gets up to temperature and wire it up to be on when the engine is running and not up to temperature.
For now I'm thinking of just using a simple switch and later using more complicated logic when I make my digital dash which would already have a temp sensor running to a microprocessor so it would not be much to have it signal the heater.
If my current sensor is bad I'm planning on doing the swap next weekend so check back next week if you are curious how this turns out.
