is there an easy way to adjust idle speed?
idle adjustment
Originally posted by JDG View Postwell what are you working on?
Adjusting Idle
Is there an easy way to adjust idle speed. I was thinking there was a way to make it so my throttle is pulled back just a hair, but I'm sure myself. My 351 Lincoln is havin issues at idle, It doesnt feel like a misfire, it just seems like its idling to low to maintain itself so i usually have to keep my foot just a hair on the gas to keep it going. It has been in storage for 10 years and just came out this year, but was still just left sitting 99% of the time.
should be an idle speed screw on the carb near the linkage
Originally posted by Lincolnmania View Postshould be an idle speed screw on the carb near the linkage
Need to figure out if the choke is working right first. Does it idle high when you first start it, then come down, or does it idle really low all the time? If it doesn't idle up when cold, the choke system isn't working. Quite probably its gummed up from sitting. Usually a washdown with carb cleaner and manually working the linkages will make it go.
If you read over those pages, it shows the choke system and how it works. You'd be looking at the hockey puck on the side of the carb. High idle screw should be on that side, regular idle screw on the driver's side. Fuel mixture screws are on the front side of the carb all the way at the baseplate. I wouldn't mess with those before being sure the choke works right. If its been sitting 10 years and the carb has not been rebuilt, you may want to do that. Chances are its either half clogged with varnish, or the accelerator pump is dried out and not working properly anyway. Torn accel pump diaphragm or a sticky float will make it run rich too.
**threads also merged**Last edited by gadget73; 01-29-2010, 08:59 PM.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostNeed to figure out if the choke is working right first. Does it idle high when you first start it, then come down, or does it idle really low all the time? If it doesn't idle up when cold, the choke system isn't working. Quite probably its gummed up from sitting. Usually a washdown with carb cleaner and manually working the linkages will make it go.
ok so the choke works then. You'll need to tweak on the regular idle screw, which you should find on the driver's side of the carb, somewhere mixed in with the linkages. If yours has the plunger thingamabobby, the idle screw is the long screw that moves the whole plunger giggy around. I think its a 5.5 mm or 3/16" socket.86 Lincoln Town Car (Galactica).
How about efi? I don't have any problems with mine, just curious as to how it works. What is normal warmed up idle speed? Does it vary from car to car or what?sigpic
Originally posted by 1990LTD View PostHow about efi? I don't have any problems with mine, just curious as to how it works. What is normal warmed up idle speed? Does it vary from car to car or what?86 Lincoln Town Car (Galactica).
Discussions on this website are a lot easier to follow when each topic has its own thread, even if there are a lot of active threads at the same time. Plus, it makes searching easier later.
Originally posted by gadget73There is nothing more permanent than a temporary fix.
