Since finding this out on my p72 Ive been curious.. did some looking at the junkyard and at my 91, and this seems to be correct. These are also the years with the modern master cylinder style and what I guess is a restrictor/shutoff valve in the rear line at the MC.
Every 88-89 I looked at has just some sort of junction block for the front lines only down on the frame rail and a dedicated line going directly to the rear. The 90-91's have nothing on the rail with two lines for the front coming off the MC.
This is probably good info for anyone wanting to upgrade the old style MC... I'm still not sure what it means you would need as far as valves - whether you would have to eliminate the frame rail one or not.
Either way, it looks like there will be lots of new plumbing involved.
Attached are pics of the three different scenarios...
And it looks like the 85's header flange ball is leaking a little bit... I thought I felt those threads giving out when i tightened it up. ggrrrr...
