i got an 89 lincoln town car. total noob so ill need the the tools ill need and step by step of how to do it.
i want to flush my heater core
moved to the appropriate forum.86 Lincoln Town Car (Galactica).
Tools:
5/16" nut driver
Garden hose
Water spray nozzle.
Water source.
Undo both heater hoses from engine side.
Place one hose so its discharge doesn't soak engine, or feet.
Turn on water to garden hose.
Shove spray nozzle into hose if it fits, otherwise seal tight with your hand.
Activate hose. Run water for as long as you like.
Swap hoses, and repeat.
Reinstall heater hoses.
Top up coolant level as required.
Turn off water spigot.
Roll up hose.
Alex.
That's how I did it.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
- Oct 2009
- 2878
- Keene NH
- Send PM
Originally posted by GM_Guy View PostTools:
5/16" nut driver
Garden hose
Water spray nozzle.
Water source.
Roll up hose.
Alex."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
hey
Originally posted by 91grandmarquis View PostJust out of curiosity could the pressure from the hose blow anything out or harm the heater core? Im talking about if it has a squeeze type nozzle or if you should just place the end of the garden hose without the nozzle in the pipe to flush it.My wife and I.sigpic
hey you should go to the store buy some coolant flush then run the flush through your whole system then then flush both sides the heater core side and the engine side through the heater hoses. when u do the engine side run the engine.My wife and I.sigpic
same pressure with or without the nozzle. With both pipes unblocked, it probably won't matter much, though I'd probably only suggest doing this if you have poor heat and as a last ditch effort before replacing the core. If its massively clogged up with crap, dislodging it may cause it to spring a leak. If the heat is working fine, I'd probably leave well enough alone.86 Lincoln Town Car (Galactica).
- Oct 2009
- 2878
- Keene NH
- Send PM
Yeah I was just curious my heat cranks, Sometimes it is way too hot. especially if its like 30+ out."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
true, but considering how many people balk at the idea of replacing the core I figured I'd put a warning in there. I've done mine twice now. It sucks, but its not the end of the world. The second time I pulled the air box out totally and rebuilt it with new hinges. That kind of sucked, but now everything works perfectly so it was worth it.86 Lincoln Town Car (Galactica).
5/16" nut driver
Garden hose
Water spray nozzle.
Water source.
Roll up hose.
Alex.
