Ok, so basically this may be a stupid question but is it worth it to convert ot MAF when I do the HO swap, I mean ill have the engine apart and access to everything so if Im going to have to install sensors or what not itl be easier. Not really sure what it intails or if its worth it.
Question about MAF
- Oct 2009
- 2878
- Keene NH
- Send PM
Question about MAF
1985 GMC 1500
Tags: None
Just depends on what your going to do with it, if you plan on future upgrades like a cam or something do it. But if not just leave it speed density. I however always recomend going mass air if you have the chance. It costs a little bit more, but its an easy install only took me about a half hour to wire mine into the ecu.
mass air = flexibility for the future
speed density = hates anything but stock
'90 LX 5.0 mustang
Big plans
- Oct 2009
- 2878
- Keene NH
- Send PM
I am putting a new cam in with the HO swap, so I think ill just do it, What do I need to do so?"Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
no need to run maf if you are using a ho cam......use a 88-92 mk7 ecm and your cruise will still work
If you want to do it you would need a mass air computer from a 5.0 mustang. (100 dollars or so) as well as a mass air meter that coincidences with the injectors you are going to use.~David~
- Oct 2009
- 2878
- Keene NH
- Send PM
Ok Im not sure what the cam is actually, it came with the car and Ive got some spec sheet pics in my readers ride page, could someone help me out with that? Cause I was told it would work, but don't want to chance anything. If itl work without MAF then Ill just leave well enough alone."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Link to your RR in your sig. Makes it easier for us to jump to it.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
doing a mass air swap is actually not any easier with the engine apart vs together. I'd really try to find out what exactly that cam is rather than rely on someone saying "oh this here cam'll work jus fine".86 Lincoln Town Car (Galactica).
- Oct 2009
- 2878
- Keene NH
- Send PM
Yeah Thats what Im trying to figure out."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
