hey which terminals do i jump on the relay to hot wire the the pump on my 1991 gm
jump fuel pump
about halfway down. Ground the wire in the diagnostic connector that says "fuel pump" and turn the key to on.86 Lincoln Town Car (Galactica).
i'm guessing thats the relay socket. that also works, but grounding the wire on the self test connector tests the relay and the rest of the wiring since it powers things up exactly how the ECM does.86 Lincoln Town Car (Galactica).
