I want to put a manual temp gauge on my 302(cfi). Are either of the temp sensors in the manifold just for the dummy light on the dash so I could replace it with my temp sensor?
Install Temp gauge on CFI engine
Does anyone know at what temp it should stop running rich?'85 Mercury Grand Marquis
only MSD multi-spark so far but hopefully a 351 on the way.
Were some of those pictures dead remotes?
The stock 'dummy light' coolant temperature 'switch' sender is in the very left front corner of the lower intake manifold. This is what most folks replace with a sensor when installing a gauge. You may need a size adapter for the sensor, but one should come with the aftermarket gauge.
How rich is it running cold? if everything is working right it shouldn't run noticeably rich at all... but with CFI especially things sometimes don't work as they should. I got tired of always messing with my CFI and evolved itPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View PostWere some of those pictures dead remotes?
Once it is what I think is warm it runs a bit rich, it is stumbling when I take off from sitting in gear stopped for a bit(unless I two foot it to give it a little gas while sitting) and I can smell gas in the exhaust. I'm actually going to be going the other way when I put a 351 in it. I'll be going to a carb. Eventually I'm hoping to go to multi-point efi but I won't have the money to rebuild the 351 and put multi-point efi on it now.'85 Mercury Grand Marquis
Have you done much poking around yet? If you luck out it sounds like typical vacuum leak or EGR valve stuck open.
I should update those pics... and the whole thread... hhmmmmPete ::::>>> resident LED addict and CFI defector LED bulb replacements
check your O2 sensor too if that doesn't help. Seems that when they fail, the cfi runs really rich and it dips into the fuel economy pretty badly. New sensor is less than 20 bucks for the universal one, you just have to splice the plug from your existing one onto the new one.86 Lincoln Town Car (Galactica).
I cleaned the EGR, full tune-up (plugs, wires, cap & rotor), fixed one vacuum leak, adjusted timeing to 12 degrees and installed my MSD stuff(coil and MSD 5 multi spark box). Before the tune-up it plain out ran awful and it desperately needed it, some PO put new wires on but the plugs, cap & rotor were all original. I'm still wondering who puts new wires on but not plugs, generally it is the other way around.
I need to do some more vacuum leak checking. Even with it running better after the tune up I'm still lucky if I get 10mpg. I'm installing the temp sensor and thinking of running some wires from the O2(to use my DMM to get an air/fuel mix reading) so I can have a better idea of some vital signs of the engine.
I forgot these just have the one wire O2 so they are dirt cheap, still would rather get some more info from the engine before I start replacing parts. I was curious how much affect they had on the engine being as old as it is. This thing is old enough that an exhaust leak after the cats would not affect the O2 reading right? I know some newer cars it possibly could but I figure this thing is plenty old to not be affected.'85 Mercury Grand Marquis
