I found an HO upper and lower intake on Craigslist - $40. for both. What should I watch out for? Thanks
"In science it is either physics or stamp collecting." - Ernest Rutherford
- Oct 2009
- 2878
- Keene NH
- Send PM
1985 GMC 1500
- Oct 2009
- 2878
- Keene NH
- Send PM
Just called the guy, he removed the intake because he wanted a cobra performance intake on his mustang, He says he has a lot of the stuff I need ie, injectors, throttle body, throttle body spacer, and headers. Im not sure how much its going to end up costing me or if im going to buy everything but he seamed to be very knowledgeable, Also advised me to switch my firing order to that of a 351? I had never heard of this before. Anyways its an hour and a half drive so looks like im heading up sunday. Says hes got two mustangs, and has owned ten, so im just hoping hes not a rapist (fingers crossed)."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Don't change from lopo firing order unless you change to HO or Explorer Cam and change the engine computer to mustang or Mark VII.Originally posted by gadget73There is nothing more permanent than a temporary fix.
no, don't change the firing order.
You only need the upper and the throttle body. Not much in particular to look out for. If it doesn't look busted, its probably fine. Its just a chunk of aluminum so as long as its not cracked, its good.
Also surprised there aren't any more local Mustang folks. Most of the ones who have modded their cars have swapped intakes, and often have the stocker laying about.86 Lincoln Town Car (Galactica).
make sure that the upper has HO cast into it...........86 HO's and some 87 HO's use the same upper as the lopo and a 55 mm throttle body.......you want a 60mm throttle body
- Oct 2009
- 2878
- Keene NH
- Send PM
Ok thanks, so I only need the upper? I dont think ill dick him around too much its a low price so if its not broken ill take it. I do have a cam for my car that came with it, however I do not know what it is ill have to talk with the guy I bought the car from. Thanks."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Yeah you only really need the upper intake and the throttle body, as previousy stated. If you wanted, you could get the lower intake and have it ported to match the upper for optimum flow out of stock HO parts.
