CFI to carb question
    Ok, I know some of you have performed this swap. My question involves fuel delivery. I am considering a carb swap to a 4bbl in the future. I have the in tank fuel pump. How did you setup for low pressure delivery? Do you have to remove the high pressure fuel pump? Install a new pickup for a low pressure fuel pump? What works and part numbers or brands?
    NA-15.78@91.21, 80hp shot-14.48@96.21
    I just cut the power to the pump in the tank and installed a mechanical fuel pump on it.
      There is a mounting location on mine but its sealed. Was yours? Will the cam have a contact point for a mechanical one?
        I dropeed tthe tank made a sump and installed a inline 4-6 psi fuel pump or was it 6 - 8... I cant member one of the two
          I drilled out the hole for the pump. As far as the cam I put in a completely diffrent motor so I'm not sure.
            How would you go about the lines? I know CFI has two lines. How would you hook it up to the manual pump?
              I just hooked up a rubber line to the fuel line going up the pass. side and pluged the driver side line. Simple.
                driver's side is the supply tho if I'm not mistaken. Passenger side line just dumps right into the top of the tank. Usually the one thats not used is just left unhooked or capped off. Nothing special involved.
                  If you plan on keeping this car, and eventually modding it (bigger motor), I might consider pulling the fuel sending unit out of the tank, cutting the stock supply line out of the sending unit, and tacking in a 3/8th's hard line, being careful to bend the pickup end to match the original.
                  From that point, I'd run 3/8th's hard line up to a filter, and then an electric pump, and then to a line going to the carb, with a fuel pressure regulator on the other end, with a return line hooked back up to the original return line going back into the tank. I believe there are one or two guys that have done this here, but I can't recall who....
                  This is overkill for the existing engine, but if future plans call for something requiring more fuel, this just might work.
                  And of course, this is just a opinion, and should not be construed as the opinion of GMN management, or any of its subsidiary holding companies.
                    On a cfi car the pass side is the feed.
                      errr, yeah duh. i should know that. passenger side is the supply on an EFI car too because thats where the fuel filter is. nevermind.
                        Found a fuel pressure regulator from Holley with a bypass and will delivery in the 4-9 psi range, but is set at 7psi factory. It should work, but isnt cheap.
                          prob be easier and cheaper to just put a mechanical or an electric of the proper type and ditch the in-tank pump completely. Dropping the tank isn't that hard.
                            Napa sells inline low-pressure electric fuel pumps if you want to go that route.
                            Alex.
