just need to know how to get that damn cable off the throttle body lever so i can swap levers onto my HO TB. lol. thanks.
removing TV linkage from TB?
Tags: None
Do you mean the rubber bushing holding it on there? If so, make sure you have the replacement brass one handy, and start very carefully cuttin' the rubber up if you can't pry it off of there by hand.sigpic
if i could i would like to use all the same parts and bushing but i just need to get the throttle body off the car (that damn tv line) fo an hour to put the lever on my HO tb and take it to my uncles to weld it on. Then if i could, just use the same stuff and throw er back on with the rubber bushing.Finally have an on the books porting/custom fab business!
Don't reuse the rubber bushing. They have been known to fail, and cook transmissions. Instead, get a brass replacement from your friendly Ford dealer #F3SZ-7H303-B. It's held in with a cotter pin, rather than just being held in by friction. Much safer.Originally posted by gadget73There is nothing more permanent than a temporary fix.
If its the plastic bushing, just pull the cable straight down. If its the brass one with the hairpin clip on top, pull the clip and the cable should fall out the bottom. Don't lose the brass bushing or the clip.
+1 on tossing the plastic thing for a brass one. You'll never have to worry about it again.86 Lincoln Town Car (Galactica).
Once I had the plastic one off, it was pretty easy to see how flimsy it was. It was actually brittle and disintegratedI kept it in the same bag on a shelf with the spare brass bushing that Scott sent me and I went to take a picture one day to compare the old one vs the new one and all that was in the bag were little pieces of black plastic, black dust, and a brass TV bushing
alright I got it. It's the black rubber one I got on there and doing all this work on the car in the -10*C un-insulated garage made that rubber like steel lol. I just heated the rubber up a little and pulled the pin out. got the lever on my HO TB fine to! ...those bushings inside the coil return spring on the throttle lever don't like welding level heat to much BTW. The rubber is in great shape so i'll leave it until spring and get a brass bushing for it.Finally have an on the books porting/custom fab business!
trust me on this, get the brass bushing asap. $5 for a bushing or $1000 for a transmission. Easy math.86 Lincoln Town Car (Galactica).
Coming from someone whos had the rubber bushing fail. Buy the brass one. Now.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
I bought mine from Scott he might be able to sell you some... I couldn't find any locallysigpic
