It was -24 today with windchill and my car is basically useless right now. It has power locks. I tried to unlock the driver's door, and the lock didn't turn all the way. I didn't want to twist the key so I tried prying on the door and used some lock de-icer. I pulled the handle again and it it gave way and went straight up, so I'm thinking a rod came loose in the door panel. The same thing happened on the passenger side with the exception of my key being twisted. So how it is right now, the car is locked, both locks aren't working, and the door handles slipped loose from the inside.
A lot of people are probably having this problem or did before, so what can I do to fix it? Thanks.
