Sounds like folks need to do some lock system maintenance. Unfortunately most of this really ought to be done before freezing weather hits, otherwise it might be too late. What I usually do is flush all of the latches, lock cylinders, and any other moving parts out wth wd40 to get rid of any water. Once that dries off, a dose of white lithium grease in the latch and a small dose at the various moving points to keep things free usually does the job. You can do the same thing with the lock solenoid if its not seized. Get any water out of it, then lube it with grease. If the boot is torn, you can't keep the water out though so its really time to replace the thing if the boot is shredded.
I'm having a big problem with my doors
- Oct 2009
- 2878
- Keene NH
- Send PM
Originally posted by johnunit View PostIt appears that's what it was.
I gave in and threw 50 bucks at a guy from Diamond towing to use a slim-jim on it.
The damned thing was so frozen that the front locks wouldn't budge. Eventually he got me in through the rear door. As an unintended (but pleasing) side effect, my mother is now convinced that I should have the underground parking spot whenever it's below zero. Maybe I'll finally get the other 4 plugs changed"Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Originally posted by gadget73 View PostSounds like folks need to do some lock system maintenance. Unfortunately most of this really ought to be done before freezing weather hits, otherwise it might be too late. What I usually do is flush all of the latches, lock cylinders, and any other moving parts out wth wd40 to get rid of any water. Once that dries off, a dose of white lithium grease in the latch and a small dose at the various moving points to keep things free usually does the job. You can do the same thing with the lock solenoid if its not seized. Get any water out of it, then lube it with grease. If the boot is torn, you can't keep the water out though so its really time to replace the thing if the boot is shredded.
I just don't shut the door all the way, I just go to the first click. It opens a lot easier. Last year I had to get in the back and clime over the seat. I park in my driveway so I don't lock it anyway.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
Originally posted by 86VickyLX View PostDo they actually sell the boots by themselves?86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostNot that I'm aware of, but that would be nice. I've got at least 2 good lock motors with no boots here. Useless without the condom though, they'd be shot in a month.
I think you just found your solution. A condom with zip-ties on each end.sigpic
1988 Grand Marquis LS (White Lightning), 2003 Mercury Marauder (SOLD),1979 Mercury Cougar XR-7
http://landyachts.homestead.com/page5.html,1951 Merc on a '88 Lincoln Town Car Chassis:http://landyachts.homestead.com/index.html
doubt that would be durable enough, unless your junk needs a *lot* heavier duty protection than is available around here. I did try fingers from a rubber glove once. Worked for about 2 days before tearing.86 Lincoln Town Car (Galactica).
Originally posted by 91grandmarquis View PostSo is the root of the problem moisture freezing in the solenoid when the seal wears out? or do they just go bad, i know mine is bad because it started last winter and no longer worked over summer.
my 85 merc however is differnent tho. the lock cylinder seems to keep icing up.
I have dodged the frozen locks since I've started putting the flap on late in the fall.
Alex.
Originally posted by GM_Guy View Post
Illuminated entry? Make an electric tape flap to cover the key hole and seal the edges. What I found on mine is that the illuminated entry face collects water. The only place for it to drain is to seep into the lock cylinder, which in turn seeps out the back of the lock cylinder, runs down the lock rods, and usually straight to the lock solenoid, and anywhere else. And then _everything_ is frozen.
Alex.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
I plan to go to a couple of wreckers this weekend. Do you want me looking for specific parts? If so help me understand what is needed.
It is going to drop down to 60 F / 16 C, but do not worry I will bundle up and wear gloves. (After growing tired of two official languages and the weather, I moved to a warm climate.)
Take care
I got my doors opened today finally. The driver's side door was unlocked but the rod came off the handle so I couldn't get in. I thought the passenger side did the same thing but I called my uncle to see if he can use a slim jim on my back doors, and he said to just cover the lock with tape and pour boiling water over it and the rest of the door and keep locking and unlocking the door. I tried that and after a couple of minutes the door lock loosened up and the handle worked and opened up. Now I just have to see what I can do to prevent this later on."It is the soldier, who salutes the flag, who serves under the flag, and whose coffin is draped by the flag, who allows the protester to burn the flag."
-Father Dennis O'Brien, USMC
Originally posted by Ringting View PostIt is going to drop down to 60 F / 16 C, but do not worry I will bundle up and wear gloves. (After growing tired of two official languages and the weather, I moved to a warm climate.)
Take care86 Lincoln Town Car (Galactica).
