Yo fellas,
I know there's info on a Lopo conversion to HO but the info is speratic, would you fellas know a thread that lists almost step by step of beginning the Conversion process. I have most of the parts for the HO, just need the ECU.
Parts I have is:
8 19 lb injectors
Explorer throttlebody, upper/lower intake
Mustang '89 cam
Powersteering pump
Water pump (current one is shot, empeller inside is shot to hell)
EGR spacer borred
springs (front & rear) lower car 1 1/2 - 2 inch
Shocks (front)
Radiator (installed)
Timing chain
I guess what I'm askin is step by step proceedure to uninstall lopo parts an intall Ho parts. I think the Cam an timing parts might be the trickyest. Pix would be apprsheated fellas. Still a Noob worken his way up the todem pole.
Thanx fellas,
Drew
Parts I have is:
8 19 lb injectors
Mustang '89 cam
Powersteering pump
EGR spacer borred
Shocks (front)
Timing chain
Thanx fellas,
Drew
