Hello. I have a bit of a dillema with my 1989 GM with 302. Yesterday I went uptown and and smelled antifreeze. So I pulled over and found the drivers side valve cover covered with coolant. Level was ok so I went home and spent some time trying to find the leak. The coolant was sitting on the lip of the drivers side valve cover (near the rear) and dripping onto the exhaust manifold. I cleaned it off and couldn't find anything leaking. I came here and started reading horror stories about rear intake manifold gasket leaks and frost plugs that let go. The 2 coolant hoses to the egr body spacer are in good shape. So nothing was leaking now(of course everything was warm and was expanded).
Fast forward to this morning. I started the car before going to work (-20 C) and everything was dry. It warmed up a bit and I revved it up. Coolant was dripping between the throttle body and EGR spacer!!
It was running over the valve cover, running down the lip and heading for the exhaust manifold. I thought I would check the bolts. The top 2 were snug but when I went to check the lower front it turned easily. I didn`t hardly turn it and the nut and a 1/2 inch of the stud came out.
WTF!! The end of the stud was ALL rusty with only a tiny sliver that was shiny so I guess it was broken off for awhile. I`ve owned the car for 8 years and a friend had it for 3 years before that so I know the throttle body was never off.
So anyway what do I do? I ordered the 2 gaskets at a local auto parts store. The stud is unavailable from ford as well as the auto parts store. Im guess I can use a bolt and make one. I asume it is metric.
So I guess what I am wondering is it as easy as removing the 3 remaining nuts and sliding off the throttle body and egr spacer? ( am hoping there is enough of the broken stud to grab onto with a vice grip). Cleaning it up well and reinstalling the egr spacer and throttle body with new gaskets??
I have started soaking the remaining nuts with PB BLaster.
What would happen if I just removed the 2 coolant lines and plumbed them together?. I really don't want to do that but would the throttle body or EGR ice up? We don't have any vehicle inspection requirements here.
I line in Northern Alberta, Canada so it can get mighty cold (-40). I also wonder if there is a possibility of a lean condition with the broken stud allowing a poor seal? I also hope that no coolant has leaked INTO the throttle body while I was screwing around, but I didn't run it very long or hard.
I know this is long winded but I would appreciate any help anyone can give me. Thx.
