Originally posted by andymac0035
View Post
1990 CV Wagon Cranks but No Start
New plugs, cap, rotor, distributor, and battery cables later, I still have no start. I even cleaned the connectors for the injector harness.
It very briefly ran for a couple of seconds but it was more of a stumble and died quickly. I spent half an hour looking through my garage again for the old 89 ECM but no luck. Next step I can imagine is to tear down to the timing chain. Not at all looking forward to it, but it's all I can think of from here.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Did you double check the ECM ground at the battery?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
i was gonna ask this as well, i got a 94 merc sable once for free cause it just quit on my buddy. he tried everything then gave up. with a little time with the volt meter i found the power wire was fucked and intermitenly gave some juice. it ran like a watch with a new wire
Originally posted by 85crownHPP View PostDid you double check the ECM ground at the battery?2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Yeah that sounds like it. Did you eliminate that factory squeeze connector? One of mine was all kinds of nasty inside it.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I didn't eliminate the connector- it appeared clean, but if it's known to cause trouble I'll cut it out to be on the safe side. Not like the connector serves any reasonable purpose when everything else on the cable is permanent.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
You better start recalling better fast! Haha! I'm straight up out of ideas.
When you say it disabled the car, how badly was it disabled? It's firing on some cylinders which tells me some things are working some times...2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by Freshmeat View PostYou better start recalling better fast! Haha! I'm straight up out of ideas.
The one wagon, however, was running like bleeaggh, and it was traced down to this one wire fairly quickly, as I had been having trouble with the battery terminals on this car.
Please recall that this was around 7-9 years ago.....
It could be on the positive side, or the negative side, I don't have a Box out front to go run and check on. But for some reason, I recall it being on the negative side....
Originally posted by 85crownHPP View PostDid you double check the ECM ground at the battery?Last edited by Guest; 01-11-2010, 01:51 PM.
Well, this has brand new cables on both sides and I reconnected that wire. I'll delete the connector and see if it helps any. I may pull an ECM at the yard just to see if it helps, but I'm not thinking that's the issue.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Again I say MAP....when mine went, I would start it, it would fire on a few cylinders and then die. It was very frustrating.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Is there a way to test the MAP without buying a new one to replace it?
I'm going to thoroughly go over all grounds again Tuesday afternoon to see if I find anything missing or in bad shape.
The local Mustang shop says there's a ground (supposed to be) bolted to the back of the intake for the injector harness that's known to rot out. I'll check that and if I don't get anything he said he has a 89 CV from which I can rob the ECM and see if it helps any. It's time to get this thing going!!2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by 91waggin View PostAgain I say MAP....when mine went, I would start it, it would fire on a few cylinders and then die. It was very frustrating.
This is an electrical issue associated with the ECM, methinks.
Did you check the 'salt and pepper' connectors? I've heard of them corroding their pins out too. These are the ones next to the TB that have the wires for all the injectors and sensors. I don't think the coil wiring is part of it but I may be mistaken.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
