Thunderbird ECU work for HO Upgrade??
    Yo fellas,
    I snagged a '94 HO ECU from a thunderBird with 'Mass Airflow' Sensor' on a count that mine ('90 Lopo Vic) has a Stock 'Mass AirFlow Sensor' aswell.
    My question is did I snag the right kind of ECU or do I specificlly need one from either a mustang or mark Vii ??
    another quick question, the thunderbird ECU says 'reman', meaning remanufactured, think its a good idea to keep it or look for one that is OEM?
    1990 EFI Crown Vic Lx sigpic
    1964 Lincoln Continental (not running)
    1963 Lincoln Continental (running)
    1995 Honda Accord(Stolen)
    wont work.....94 is a 4.6.......and the 5.0 ho turds and cougars theres something weird about those ecm's and they wont work
    if you want a maf ecm, 89-93 mustang
    speed density 87-88 mustang, 88-92 lincoln mark VII
      DAMIT....SHIT....
      I should of asked before I smuggled the ECU out....
      Thanks man for the info
      Now I know.
        The 5.0 tbird ones also won't work easily unless you do a fair bit of re-wiring to the harness. A lot of the pins are different vs what the stock harness uses.
          Ditto to what everyone else has said....it won't work, especially if it's a 1994 unit. I have a 1992 5.0 HO Thunderbird, and the ECM is different from everything else out there. So different, that I'm probably going to shitcan the stock ECM as a result, and lose the EFI. The only other option for my keeping stock-based EFI is to snag an ECM out of a 1994-1995 Mustang GT, and switch a few pins around....the Mustang unit even works better than the T-bird unit out of the box.
            Thanx for the help fellas...
            I have all the HO parts ready to be installed, but this ECU mishap will off set my plans about a week or two make it three cause of christmas week. Those mexicans are a crafty bunch, they go straight for the good stuff when a handfull of mustangs an mark Vii are dropped off at the junk yards...
              Nobody steals Mark VII computers. they're speed-density, and not very desirable as a result. Mustang mass air ECMs go for money though.
