The alt in the '91 GMCP crapped & took the battery down. I swapped in a different alt & it ran ok for a few days then ate the battery, It was old so I figured the bad alt had weakened it.
The car sat for a few weeks & I had to move it for street sweeping, the booster pak couldn't turn it over I had to jump it.
Today I had to move it again & it wouldn't even jump start. I swapped a good bat into it, started right up.
I noticed the key switch felt "tight" & notice that the key was kind of sideways in the slot. The ign sw was replaced about 2 years ago.
It is also doing the headlight/ign key ding w/door open & no key, If I jiggle the key sw (no key inserted) It goes away, sometimes comes back on as the door is being swung shut....
So, It seems to be the aftermarket key switch is failing, or has anyone had any other experience w/this?
Thanks in advance......
