hey guys. i recently picked up a '87 crown vic 2-door as a winter/dd.
first a little background on the car:
Ford racing 4.10 rear gears with track lock. 5.0l HO motor swapped from a similar year mark 7. BBK shorty headers into true duals, no cats with flowmasters
real ghetto cold air intake that i plan to return to stock.
since i bought the car it has had a surging idle that i've been chasing but just recently within the last month it has become more than just at idle. it will start bucking and jerking while driving in ANY gear at cruising speeds. under hard accel its ok. its also TERRIBLE on gas. i've owned an '87 grand marquis and a '91 crown vic and both were no where near this bad. its really starting to piss me off so i've come to you guys for some advice.
so far i've done the following:
motorcraft plugs, cap and rotor. Ford Racing plug wires. motorcraft fuel filter. changed oil/filter. cleaned IAC (no change). inspected for cracked/broken vacuum lines (all look ok). inspect PCV valve (moves freely)
so any other ideas would be awesome before i burn this fucker to the ground! thanks guys!
heres a shity pick of the new vic next to the marauder.
