The procedure of removal and installation of the transmission as described in shop manual is pretty clear, I would like just ask you about the necessity of any special tools. Concretely the shop manual mentions these:
1) Shift Linkage Grommet Removal Tool T84AP-7341-A - to disconnect the manual rod from transmission manual lever at transmission;
2) Cooler Line Disconnect Tool T86P-77265-AH - to disconnect oil cooler line from the fittings on the transmission; and
3) Shift Linkage Grommet Installation Tool T84AP-7341-B - to connect the manual linkage rod to manual lever at transmission.
Do I really need them or could it be substituted by some other regular tools?
Thank you.
Thank you.
