Ok .....
My Crown Vic is all screwed up. The person that had the car before me has set the idle on the car very high to cover a problem with the car. When my mechanic realized how high the idle was and set it to 900 it wont run longer then 20 seconds. Also, if I put it in reverse or drive it will die. Does this sound like the Idle air control valve? or something else.
