I like the thought of a pipe-threaded drain plug.
Tap and dye
Originally posted by andymac0035 View PostI picked up some oversize plugs because my drainplugs threads are getting a tad "sloppy".
I noticed it says on the package "do not use unless pan threads are stripped".
I figured I would be better to use it "before" they stripped?
.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by 1987cp View PostI like the thought of a pipe-threaded drain plug.
...although, I'm not sure 1/4" would be sufficient for a secure fit. I'd go 3/8".
...and make sure the surface is thoroughly cleaned first.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
so leave it be!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View Postso leave it be!Former panther owner
1981 CV 351 4bbl
1991 CV 302 EFI
the oil drain plug is only supposed to be snugged down. Don't reef on it, the threads are shallow at best.86 Lincoln Town Car (Galactica).
replace the drain plugs about every 10 oil changes......cheap insurance at 3bucks a pop
OOoo....I got that covered!
I actually have a spare set of regular sized new drain plugs as well as a baggie of different washers. Although i do not know if the "help" brand of drain plugs are made of "softer" metal than the pan like the factory plugs are.Former panther owner
1981 CV 351 4bbl
1991 CV 302 EFI
