I've recently noticed when i go over 45mph or when Im on the expressway doing about 70-75mph my steering wheel shakes, and I can feel something vibrating on the froint end..Feels like one of the tires is bouncing...?
Shaky Front End
check your tires!
first how old are they? as they get older, the chances of the cord seperating from the belt increases......this causes the tire to become out of round
check the tread for even wear, cupping will cause vibrations
if the tires are less than 5 yrs old and they appear to be ok, have them balanced
Thanks Scott...
I put them on last september....But have rotated them recently...The tred wear is not even at all on the front tires....one of the front tires has little tred left from burnouts and slipping through snow last winter. I just took them to the tire shop not to long ago to have the rims sealed as they began to leak...But I don't remember if they balanced them.
Could one have a broken belt from hitting pot holes or something?
yeah, could be a lumpy tire. Jack the car up and spin the tire. If its real bad, you'll see the flat spot or the lump.86 Lincoln Town Car (Galactica).
tire could be messed up from dismounting/mounting a used tire when the stuff was cleaned off the wheels......jack it up and spin the wheel by hand and take a look at the tire
the hood shake is kind of normal, but steering wheel shake is not. The hood can be adjusted by tweaking the bumpers at the corners of the rad support, but mostly its just a flat flimsy piece of steel that bends and wobbles as the air runs across it.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postthe hood shake is kind of normal, but steering wheel shake is not. The hood can be adjusted by tweaking the bumpers at the corners of the rad support, but mostly its just a flat flimsy piece of steel that bends and wobbles as the air runs across it.'90 Mustang GT vert
'89 GM - 189K & rising
'07 Daytona - cuz i don't have enough money to build a car this quick
well, yeah shit roads will make things shake a lot too. Accurate diagnosis requires ruling out bad road surface86 Lincoln Town Car (Galactica).
