two question i need answers two
    Mine is on the hinge and has a white button. Its somewhere in that area tho. If you smack it and it goes "pop" and the motor dies, thats the one. Just push the button on top when you're done changing the filter to reset it.
    Fuel filter is on the passenger side in the back, just forward of the rear tire. Its got two small screws holding a plastic cover on, and then plastic hairpin things holding the fuel lines on. Make sure the new filter comes with new hairpins, you'll almost always break one of them removing the filter.
    PCV is positive crankcase ventillation. Sucks the oil fumes and blowby out of the crankcase. If its not working, you'll usually see oil film in the throttle body and it will tend to leak more oil. The stupid screen underneath the valve is usually more the problem. Its called a pcv filter, and looks like a wad of steel wool jammed into a metal sleeve. Use a long screw and a pair of vise-grips to pull it out.
    My bad...Mines hanging on the trunk arm too....But my brothers 89 had it behind the carpet.....Ughhhh....Sorry about the fuel filter mix upp..Mine is on the passenger side but my Grand Marquis was on the drivers side....LOL.....Ughh..Don't listen to me to man panthers on the brain.....
      Originally posted by KING BIOHAZERD View Post
      i live in brookfield right off of ogden
      That's not to far I live in Westlawn/Midway.....Dam PCV Valve...It's there..I wish I could get a good diagram for ya but I can't find any
        The pcv valve is ummm well, look and see where you distributor is. you pcv valve is in the same spot opposite the dizzy on the back of the engine against the firewall, and like everyone else said worry about the screen not the actual valve. you pull the pcv valve out once you find it and its down in a hole in the block like the dizzy hole and you just screw a long screw into it and wiggle it out. I hope this helps
        '90 LX 5.0 mustang
        Big plans
          see the vacuum line coming out slightly to the left at the very back of the intake, and the circular vacuum thing on the wiper box slightly to the right ? in between those straight down at the back of the intake.
          '90 LX 5.0 mustang
          Big plans
            ok from looking around the site i think its going to end up being my tps sensor cause all the post i have read sound like this is my problem!! i think finger crossed good thing is its not very much bad thing is iam out of money
            sigpic1987 grand marquis
              Perhaps you should scan the computer for codes before throwing parts at it. It may point you in the right direction.
                i just changed my fuel filter too its simple, just try not to inhale too muck of the gas vapors if gas leaks out, also after u change the filter u have too turn the key right before the car starts but dont turn it on this is to charge the gas pressure up do this five times check for any leaks too!!!
                yea i have to change my pcv stuff too im getting gunk in my oil
                i started my HO conversion too!!!! wish me luck cause its a pain!!!!
                  ok but how do i scan for codes
