oil cooler
    oil cooler
    What is the maximum length of the oil cooler lines from the engine to the engine oil cooler? The lines are like 6' a piece and -10an [5/8" OD]. The cooler itself is 7x11 inches...
    I am curious because I am considering re-routing the lines...
    https://www.facebook.com/jason.baker.1614
    1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
    1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
    2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
    2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
    Rerouting the lines, how?
      Never heard of any specific length required, or max length. How are they routed now?
      '90 LX 5.0 mustang
      Big plans
        They come straight foward and around the radiator to the cooler. I want to re-run them so they are out of the way more.
          Go for it. There should be no max length.
          1990 LTD Crown Vic w/ dead 5.0
          1984 Pontiac 6000 cammed 2.5L Iron Duke
          1986 F-150 300 6cyl 5spd.
          1994 Crown Vic... Free, bad trans?
            I just do not want to stress or break the oil pump [if thats even possible]. Thanks!
              Length should be no problem, as long as you keep the same size lines and fittings.
