I applaud your hot rod efforts.
Nitrous CFI in the Works!
Latest update on this project: Completed all the wiring today! Installed the arming switch, relays, and wired the nitrous solenoid. Dry tested the system without nitrous (my friend has the bottles). Everything seems to be in good order! Have to work this weekend, so i will have to test and tune the nitrous first of next week. If all goes well, will post some picks!
NA-15.78@91.21, 80hp shot-14.48@96.21
Thats pretty sweet, most people don't try and push the limits, but engines are more forgiving than most people think...just for how long is the question, but ive seen some crazy turbo stock motors that scream "that shoulda blown up by now" but it hasn't...1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by 1980c10 View PostSo how did you set this up, like a plate system for a carb or a nozzle for fuel injection?
