Mass Air or HO conversion
    Below you will see an e-mail I sent to CarCraft magazine asking about which Mass Air conversion I should go with...this was prior to finding your site. After perusing your forums, I believe you may have an answer to question #5...converting to an HO Speed Density. And it sounds cheaper/easier than some of the mass air conversions.
    If you could read the e-mail below and give comments, I would appreciate any advice given. I do have some additional HO conversion questions:
    Buy an upper HO manifold (Easy)
    Buy a HO ECM (and it really plugs and plays...NO changes to wiring?)
    Buy 19 lbs injectors (Easy)
    Buy HO cam (Um, can this wait until later and use my current cam? If I go that deep into the engine, I might as well rebuild it. I don’t want to do that due to time constraints)
    Buy HO heads (Again, can this wait and use my current heads? If I replace the heads, I might as well replace the cam... might as well rebuild the engine, but still have a time constraint problem)
    Buy HO throttle body (easy)
    I currently enjoy good MPG with my 14lbs system. Do you lose much MPG with a HO conversion? Or does it increase, by using higher compression/better air flow (later in a rebuilt engine or crate motor)?
    Big T
    -------------------------------------E-Mail to CarCraft-------------------------------------
    Hi,
    I have a 1986 Mercury Grand Marquis. It has a 5.0L with an AOD trans. I have modified the car as far as I can with the speed density system. I get about 20 MPG, which is not bad for a heavy 4-door! I want to upgrade to a Mass Air system so I can change the cam, put higher flowing heads, headers, maybe flat-top pistons, and so on, but need some help with which Mass Air to use.
    Here are my plans for the car. It will be a daily driver with highway being the max speeds (no track time). I would be surprised if the engine RPMs would ever see 5,000...85 MPH is the most I’ve ever driven it. So I plan to use a mild cam, or even a towing cam. I’ve heard they have good MPG and great torque (I do have some stop and go traffic on the way to work).
    Here are the Mass Air routes I can take:
    1. Buy a Mustang donor car - This is the most labor intensive. The harnesses do not match, but I get a 19 lbs injector system.
    2. Buy a newer Grand Marquis donor car - A little less labor involved. The harnesses are closer, but it is a 14 lbs injector system.
    3. Buy a Mass Air Conversion Kit - This is the route I’m leaning towards. It is less labor then above options. Seems pricey for what you get, and I still have to buy injectors.
    4. Buy an after market Mass Flo type System - This is the most expensive. I could build or buy a new hopped up engine for the price, but the reviews are great.
    5. Open to any ideas I have not thought of....
    Oh, 14 lbs vs. 19 lbs injector systems? I know I would get more power with 19, but do you lose much MPG with them? On the other end, would you really get that much benefit from engine modifications with a 14 lbs system?
    George Burns
    First yes you really need the H.O. cam if you run the H.O. ecu because they are diff firing order than the lopo. I did H.O. and mass air on mine no big deal, and I didn't by a kit I just bought a used mass air meter off ebay along with the H.O. mass air ecu and a mass air sensor wiring pig tail, still have a spare pigtail if you need one. I also have specific mass air conversion instructions for a panther chassis, if you need it I can find it, its super easy took me a half hour to do all the wiring. I also got an increase in MPG with a full H.O. swap FWIW.
    '90 LX 5.0 mustang
    Big plans
      I knew about the different firing order. I had planned to extend the fuel injection harnesses to reach the proper cylinders and switch the plug wires to the right order.
      Are you saying the H.O. conversion and the Mass Air conversion are done at the same time? Or are they two different conversions, and you happened to do both (at different times) to your car?
      Mass air conversion instructions for a panther chassis, sounds great! BTW, is the chassis of my Marquis a panther? If you have it in soft copy, you can send it to tomich_automotive@hotmail.com.
      The car is scheduled to be repainted in a month or two. This is my time constraint. I don’t want to get the call we’re ready to paint your car, have the engine torn down, and miss the paint job. I’ve been on the waiting list for a year and a half. It’s a prisoner work program. They’ve replaced the vinyl roof last month and the car is looking better already!
      I was hoping to do a H.O. (or masss air) conversion before the paint job. But if I have to have the cam and heads, then it’ll have to wait until the painting is done. Thanks for the pigtail wiring. If this is route I should take, I would like to have it. What are you asking for it?
      George Burns
        I would not change the harness to a Mustang one. The Mustang stuff is all in the wrong places, so its quite a lot of uneccesary work to use one vs just adding the few pins to your stock harness. I pulled a harness from an 86 Vic in the junkyard when I did mine, and used that as my conversion harness (I had already done the HO, so for me it was just an ECM and wiring change). Fair warning, the 86 harness is a smidge different than some other years, so if you go seeking a spare harness for this, make sure its a 1986 harness otherwise you'll find a few plugs don't land where they should.
        Honestly, if you're going with a stock HO, you don't need mass air. There is no real atvantage to it on a stock motor. You can also just swap to mass air later on, when you're ready for more work.
          I wasn't going to change out the whole harness. I meant to say, I would splice wire into the current fuel injector wires so they would reach across the manifold and place them in the correct order. But maybe that's not a good idea for injectors.
          Eventually I would like a rebuilt or crate motor installed. The current 5.0 has over 200K miles on it. First I wanted to have a good mass air system on it to be sure it would run before I spend the money on an engine. But now a H.O. conversion may be better since I don’t plan on a big cam. Either way, it sounds like I may need to wait until it’s painted, then I can spend more time on the conversion.
          Thanks for the info!
          Big T
          George Burns
            HO conversion FIRST... then convert to MAF, if you need to.
            there is no need to splice and/or modify anything on the fuel injection harness!
            only thing you have to do is add 3 wires to the main ECM connector and re-locate 4 wires in the connector.
              I bought the MAF sensor pigtail kit from IST
              complete instructions how to wire it in.
              http://www.mass-air.com/Products.htm#Mass-Air Harnesses
                1980c10 can you send me a copy of those intructions too 83countrysquire@gmail.com
                  Mine came from the same place. Wiring info did come with it, but it was a little skimpy for my liking. I used the ones on lincolnsonline as they seemed easier to follow for me.
                  And yeah, you don't move around the injector wiring. Injector firing sequence is controlled exclusively by the ECM. Swapping the injector plugs around is not neccesary, and will cause you problems. The wires that get moved are for smog control stuff, not the injectors.
                    Big T
                    Uh, the more simpler way to rewire the injectors would be at the salt and pepper shaker connectors. Just moving pins around.
                    Read more of the stickies, search around. There you will find your answers. Some reading up on basic engine principles and how EFI works will help you a lot too.
                      Ok guys I will see if I can find my instuctions.
                      And bigt the H.O. and mass air are seperate conversions I just did the mass air while I was doing the H.O. swap because I have scary future plans haha.
                      '90 LX 5.0 mustang
                      Big plans
                        here are instructions for a lincoln lsc, can't find mine right now but I had these instuctions and panther specific ones and they are exactly the same other than the ecu locations and such, the wiring is all correct for a panther Trust me it's exactly the same as the ones I used for mine and its ran perfect for a year so far. anyway my other set of instruction are prolly still in ohio at my parents since I just moved to va.
                        '90 LX 5.0 mustang
                        Big plans
                          Zen and the Art of MAF by Jim
                          In your quest for improved performance, suddenly your Lincoln has hit a brick wall,.no matter what you screw on it in terms of trick parts and pieces it won't speed up,..in some cases it even slows down,.driveability goes to hell,.worst case scenario,..you've blown a head gasket. Welcome to the outer reaches of Speed Density fuel injection controls. Speed density is great,.realistically a lot simpler than Mass-Air, but terribly inflexible. After you radically change/improve VE of the engine, the speed density system goes "tilt" because the load/fuel mixture tables are chiseled in stone,..buried in the processor,..so when you exceed these parameters, the system can no longer effectively compute injector pulsewidth (fuel/air ratio) and timing. The net result is loss of driveability, or in extreme cases, engine failure due to detonation caused by lean mixtures and/or over-advanced timing.
                          Yeah, I know you naysayers are saying "but a custom chip will fix this",,correct,.IF you have access to a chip burner and a wheel dyno with A/F monitoring equipment,.but do you want to have the chip (re)burned every time you make another mod? You can change the air/fuel/timing parameters in the speed density system, but you can't get rid of the inherent inflexibility that is designed in to the system.
                          The cure to this dilemma is a Mass-Air conversion. The first hurdle is the cruise (see LSCMAN's and my earlier posts) and the second is the message center in the dash. Contrary to popular opinion, the dash computer WILL work with the Mustang MAF processor. The only input to the message center from the processor is a fuel flow signal from Pin 34 DOL (data out line) . This pin is unused in the MAF 91Stang application, however the pin and signal do exist (contrary to the vague answers I received from FMS, FoMoCo, and virtually everyone else I asked).
                          Another thing,..all of these changes made to my LSC were done over a month or so,.NOT a weekend. Once a racer, always a racer. Never change more than one thing at a time. Even though you've got my rambling drivel for instructions DO NOT try to do all this in one fell swoop. One step at a time,.that way if something goes schitzo, you KNOW what it was and at what point things went awry. I did cruise conversion,.190lph fuel pump,.MAF conversion,.30# injectors/chip,.and then the KB blower,.and subjected it to cold starts, heat soaks, and everyday driving between each change.
                          Scrounge Parts!
                          You need an '89-'93 Mustang MAF EEC-IV processor (stick or auto, either will work, but the stick processor is better for performance applications), a MAS (mass airflow sensor) and the wiring plug for the it, and two air intake hoses for a MAF 'Stang (about 35-40 bucks at the Ford dealer).
                          Disconnect and plug the vacuum line to the MAP sensor. Don't unhook the wires, however, it's still used as a BARO (barometric pressure) sensor for the MAF system. Install the MAS and the hoses,.make sure everything's sealed up good,..if you use silicone make sure it's the "sensor safe" flavor or the EEC will have an identity crisis right off the bat.
                          You need to get the wires from the MAS to the EEC-IV processor buried in the passenger side kick panel. Don't even think of trying to route them with the OEM processor harness unless you want to remove the inner fender liner (and if you've done your cruise conversion first like you're supposed to you'll vividly remember what a pain in the ass that was). Inside the passenger side footwell waaaay up under the dash just above where the carpet ends is the A/C evaporator drain boot(a black rubber gornick). It's held in place by a single push in fastener. Measure out (away from vehicle centerline) 2" and up 2" from this fastener and drill a BE hole. This hole will end up directly below the A/C accumulator and inside the frame rail. Feed your four MAS wires through this hole and secure,.leave 91em long,.you can stuff the excess behind the carpet when you're done. Like this....
                          Remove the EEC-IV processor by pulling out the passenger side kick panel. Disconnect the ground leads in front of the processor, and remove the screw holding processor in. Pull processor down and out on floor and disconnect the huge gob of wires by backing out the 10mm bolt in the center of the harness plug.
                          Now comes the part of the job that requires complete concentration and NO mistakes (and no Budweiser, MLH, etc?..you gotta think). On the back of the gob of wires that is the processor harness is a black plastic cover. Remove and shit-can this, cause it won't even begin to fit when you're done. This wiring (at the processor plug) is the one part of this conversion that ain't pretty when you're done,.closer to 'crude but effective,. Fortunately, it's gonna be out of sight. You need a sharp pick. Steal one from your local dentist/jeweler/locksmith or improvise. In the face of the EEC-IV connector that was closest to the processor is a red plastic insert that holds the pins locked in place (no, they aren't gonna all fall out without it). Carefully, working end to end with your pick, lever this red gizmo out of the plug. Use the pick to reach in and release the lock 'ears' inside the connector and remove the following wires,..pull 'em out of the harness,..tie 'em together,..
                          #2 BOO brake on/off
                          #35 S/C (Speed Control) vent
                          #38 S/C vac
                          #39 S/C switch ?
                          #41 S/C switch +
                          #50 S/C switch
                          These wires will no longer used. They're for the original cruise that already went south??
                          Now, ONE AT A TIME?..(trust me, do this one at a time,.I didn't and ended up checking the whole plug,.60 pins,.with a VOM to find out what I #@%&ed up)
                          Remove wire #11 and install it in position #32
                          Remove wire #51 and install it in position #38
                          These wires control the two air mgmt. solenoids directly in front of the pass. side strut tower
                          Now, the wires from the MAS. There should be four?.I'll number them 1 thru 4, starting at the intake (front) end of the MAS?.
                          #1 VPWR Splice into wire in Pin #37 on the EEC-IV connector. No &^%$!% scotchlocks,..solder it!.,
                          #2 GND Splice into wire in Pin #40 . Ditto on the solder?.
                          #3 MAF RTN Install a new EEC-IV pin ( or cut one off the discarded wires) and SOLDER it on. This is Pin #9.
                          #4 MAF SIGNAL Install an EEC-IV pin. This is Pin #50.
                          Now, take a 12'-14' long #14 or #16 wire. Glom on to another EEC-IV pin for this wire, and put this in Pin #19, FPM (fuel pump monitor). This wire has to go to the large pink/dk blue stripe wire on the fuel pump relay. Incidentally, the fuel pump relay is on the bottom of the rear package shelf on the driver's side. I tucked this wire under the trim panels, removed the bottom of the back seat, and pulled it up into the trunk. This wire can be attached with a sleazy/easy scotchlock or T-tap connector.
                          Check and double-check all your wiring and pin locations in the processor connector. Re-install the red lock insert, re-install the harness to the processor, and re-connect the ground lead you disconnected to remove the processor. Don?t reinstall the processor in it's home in the cowl panel yet,..leave it on the floor. Re-connect the battery ( you DID disconnect it, didn't you?) and turn on the ignition,..fuel pump should run for the requisite 3-5 seconds, and the 'Check Engine' light should come on. If it doesn't, go back to the 'check & re-check' step
                          Fire it up! Idle is gonna be kinda stupid at first and probably won?t be 100% until the vehicle goes through a few cold to hot cycles. Take it out and test drive/flog for a few beers/miles. No 'Check Engine' light after drivin' it? Cool! Re-install the processor up in the cowl (don't forget the ground lead) and replace the trim panel
                          Read and re-read these instructions. Get a manual that has the 'pinout' diagrams for both the MkVII and the Mustang and study the diagrams until your eyes cross. The Probst manual from FMS is a good one,.. If you never do any other mod to your Lincoln this is the one that you should!! The improvement in performance and drivability (especially at low speeds/off idle) is beyond your wildest dreams!..throttle response is dramatically 'crisper'. If you can read (and evidently you can, cause you're readin' this) and you can wire a stereo, alarm, concert lighting system, etc. (cheap shot, eh Frank?) you CAN do this. With a little creative scrounging you should be able to do it for two or three hundred bucks. If you can't find a used processor, go order one from your local parts store?..you oughtta be able to buy one for $100-$125 exchange if you don't get stupid and tell 'em what the core is out of,..just ask for one for a ?89-?93 Mustang with a 5.0 and a stick (Carquest/Cardo reman #EM681).
                          '90 LX 5.0 mustang
                          Big plans
                            Scrounge Parts!
                            #2 BOO brake on/off
                            #38 S/C vac
                            #39 S/C switch ?
                            #41 S/C switch +
                            #50 S/C switch
                            '90 LX 5.0 mustang
                            Big plans
                              disregard the part about unhooking the map sensor I didnt do that
                              '90 LX 5.0 mustang
                              Big plans
