Well, I did it! The list of goodies since the last drive!
New:
Rear 3.55 gear,
Detroit TrueTrac carrier,
Pinion and carrier bearings,
B&M Line Lock,
LED line lock indicator,
Spark plugs,
Wide ratio AOD,
--with A+ servo,
--with 4 clutch second,
--with mechanical second diode,
--with wider OD band,
--with combination Bauman/Superior shift kits,
--with shift patter OD-2-1,
B&M 2100rpm stall converter.
To do list:
Have new wheels, and need new tires to put them on. Need a new PCV screen. Need a new air filter. Then, I'm back onto improvement projects!!
Here is the link to all the pics of the upgrades I just finished. Explore my pages and learn all there is to know about the SVT Vic!!
New:
Rear 3.55 gear,
B&M Line Lock,
Spark plugs,
Wide ratio AOD,
--with A+ servo,
To do list:
