How much should a complete rear from drum to drum/disc to disc go for at junkyard? I am looking for a 3.08-3.27 trac lok to replace my open 3.08s and I'd bet a complete rear from a junked car would go for less than getting the gears setup with a new carrier. Also do the axle codes on the door stay the same for newer aero boxes? Might as well go for the disc brakes while I'm at it.
Price Check - Rear Ends
Re: Price Check - Rear Ends
Originally posted by nitroracerHow much should a complete rear from drum to drum/disc to disc go for at junkyard? I am looking for a 3.08-3.27 trac lok to replace my open 3.08s and I'd bet a complete rear from a junked car would go for less than getting the gears setup with a new carrier. Also do the axle codes on the door stay the same for newer aero boxes? Might as well go for the disc brakes while I'm at it.2000 Grand Marquis LS
Mercury Owners Group member
id shop on ebay for a trac loc, hard to find 28 spline ones at the junkyards. i paid $75 for my trac loc, shipped. got my 3.73 at the junkyard, they get $25 or so for a ring and pinnion. i was going to do the rear disc conversion, gettin the backing plates and crap from a 92+ GM or CV... after i got some new parts and some junkyard parts it was going to cost me about $160 to do that conversion. so yea... its not cheap, but if you do it yoursself its not too bad.
grand_marquis_gt: "Wow dude, you got the GMGT sedan!"
there, now im cool too
:slug: $35-50 at the local yards..........i'll help u with it if u would like
btw it was nice to see you at scottfest! it was a big hit!
scott
55 bux for any rear end at the local u pull it here.1989 Grand Marquis LS
100-200 bucks will get a complete parts car...
A note, most of the axles I've seen have wasted pass side axle bearings and axles. I'll have an extra rear in a bit, once I get the 3.73 one back from the shop.Builder/Owner of Badass Panther Wagons
The axle usually gets torn up. I used 2 drivers side and new bearings on my rear. It's no big deal, just something to check when you get the axle.
The pass rear on my wagon is howling like crazy. It's not leaking but it's friggin loud.Builder/Owner of Badass Panther Wagons
i end up using the repair bearing on the passenger side axle most of the time.....they run about 30 bucks
