i'm yanking the 84's motor to build up at some point and i was thinking about tossing it in shifty when i was done. i was gonna do a full ho on the beast but at the same time i want to clean up the engine bay. no ac, no emissions, just the motor and everything needed to run the motor. thats it. keeping it injected would be more reliable i know, but the engine bay wouldn't look as pretty. but i would have more options as to intakes and such if i kept it fuel injected.
keep the sefi, convert to carb SPEAK YO MIND
You may have better mileage with FI........
Other than that, carb gives you a huge amount of intake options depending on what your performance goals are. The biggest advantage to a carb is its simplicity and the go fast parts you can buy (or just beer) with the money you will save by not doing an EFI conversion.
4000lb Mustang.......say that over and over until it registers.
That is the key to the mindset which will get your car rocking.
I will now throw in my once a day plug for making an easy low 14 second or better car by just bolting an Explorer motor in with a better cam instead of rebuilding a worn out 302............................................... ................................done.
Convert to a carb, easier and cheaper. Also will allow you to make serious hp without flashing computors and changing most of everything for more expenive parts.
I guess I'm an EFI guy. I like being able to just hit the key and it runs. No tweaking, tuning, or dicking around with it to keep it happy every time the weather changes. It always runs at optimal, not just when the weather is the same as it was when you tuned it. Better on fuel too.
As someone (Blaze's dad actually) said "carbs change, EFI adapts".86 Lincoln Town Car (Galactica).
You'll actually have about the same amount of options for intakes with carb. and they are WAY cheaper than an EFI intake. Of course you need to buy a carb. My old carb cars were just as reliable as the EFI.
I'll also second mercracers comment. Price a decent rebuild including labor. The exploder shortblocks are a viable option. I got a complete 96 motor-oil pan to intake, wiring and injectors for 1550 from a guy on corral. So that 1550 got me essentially a GT-40 engine, all brand new. I just swapped the cam out, upgraded the valvesprings, and put a double roller timing chain in.Builder/Owner of Badass Panther Wagons
Originally posted by gadget73I guess I'm an EFI guy. I like being able to just hit the key and it runs. No tweaking, tuning, or dicking around with it to keep it happy every time the weather changes. It always runs at optimal, not just when the weather is the same as it was when you tuned it. Better on fuel too.
Then there is the cost......try pricing out a good performance fuel/ignition setup to replace/upgrade your weak factory EFI system.
