H pipe
    H pipe
    im putting true duel on my 88 and because im trying to save money i dont want to buy a brandnew H pipe. I tried the auto wreckers and they won't take one off for me. i was wondering could i just have a pipe from each manifold to the mufflers == no H . would it effect the E test? Thanks
    yes u can.....wont affect emmisions testing
      I just did that and no problems at all. Milage went down a little tho but power went up a bit. But sounds great and i don't see any problems with running true duals.
        Thats good to kno i hope Midas doesn't over charge. Whats the point of the H pipe?
          A crossover pipe, be it H or X, increases the efficiency of any dual exhaust system by balancing the pressure pulses between the two banks of cylinders. In the case of an H pipe, better low-end torque characteristics and fuel economy are frequently touted benefits, while a X pipe maintains these benefits at higher RPM ranges than an H allows. You may also experience decreased interior sound levels at low RPM.
          I wonder why a scrapyard would refuse to sell you used exhaust parts? Some odd state or local regulation, I presume?
          Also, what are you planning to have done at Midas? All you need for a quick and dirty home dual exhaust is to cut the original pipes in front of the Y pipe flanges, clamp on four 45 2.25" degree bends, and go from there. Still have all four original cats in place, no emissions concerns.
            More low end torque. If you're having exhaust made, the exhaust shop can make you a crossover in about 10 minutes with a little welding. The one on my Mark VII was custom made on the car from two pre-bent pieces of pipe and a short crossover.
              midas is the king of overcharging
              you can get a stock h pipe at autozone for under 70 bucks
                Yeah Midas does overcharge, my friend just put a new stock exhaust from the catback on his 93 Grand Caravan minus the muffler and they charged him $260 which was piping, hangers, welding and labor. I had more work done on my Sierra, custom exhaust made with larger piping and more welding and it only cost me $140 at a local shop, not a chain. Look for a small independent shop and have them weld in an H-pipe, I got mine done on my 86 Silverado for $30.
                  speaking of 'H' pipe
                  you guys know anything about CALIFORNIA rules about putting a dual exhaust on a single exhaust car
                  Now I hear that if your car came out of the factory single exhaust it must be single when you do a smog inspection. you fellas know if this is true?
                  Shit... I ask because I got talked out of putting a 'H' pipe on my Vic at the local exhaust shop
                  1990 EFI Crown Vic Lx sigpic
                  1964 Lincoln Continental (not running)
                  1963 Lincoln Continental (running)
                  1995 Honda Accord(Stolen)
                    should not be an issue as long as it has cats.......there was a dual exhaust option on these cars
                      You'd really have to ask someone who intimately knows Cali smog nazi laws. If its done using factory parts, I can't imagine it being an issue but who knows. I've heard of people failing for having the wrong year air cleaner lid, or just one that was different than the picture in their book.
                        It is possible though, that dual was NOT available in Cali, due to their emission standards. I would definitely look into it before going any further.
                        MIKE
                          Oh, no..... when and where was this?
                            Guy I knew years ago. He failed visual on his 70something MG because he had an air cleaner lid that didn't match the official California picture, even though it was the original on the car. he got a used one from a different year that matched and all was right with the world. He then moved back from the land of smog nazism and returned to NJ.
                              im in ontario and there is no autozones here. Do you recommend any places in ontario? car quest said $220 for the H pipe
