what would you all use, a 1 piece rubber gasket or a 1 piece cork gasket for the oil pan, with RTV beads at the corners? What is your preference.
cork oil pan gasket?
fel-pro one piece rubber... all the way.
I dont think you need any sealer in the corners, install it dry and make sure you torque it properly.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
felpro permadry all the way
What about on a Dodge 3.0L V6?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
One piece if at all possible. In the car, no way in hell I'd put a 4 piece cork in, simply because its a lot more work. I have installed 4 piece cork gaskets with the motor on the stand and not had leakage, but under the car, forget it.86 Lincoln Town Car (Galactica).
yeah, I think the key is clean surfaces, and an inch-lb torque wrench for the proper even torque.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by 89LincolnTWNcar View PostWhat about on a Dodge 3.0L V6?
ORLY? Thats why the pan was sealed with grey RTV, I thought someone had re-did it.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by 89LincolnTWNcar View PostORLY? Thats why the pan was sealed with grey RTV, I thought someone had re-did it.Originally posted by gadget73There is nothing more permanent than a temporary fix.
yes.....replace the oil pump and the water pump and the timing belt too while its apart......the 3.0 got a bad rep for burning oil, but they are an excellent engine.....i know how to fix the oil burning issues too if they come up
Damn rights on the oil and water pumps, timing belt as well. 3.0L is a good little engine but the valve guides are cr@p.1990 LTD Crown Vic w/ dead 5.0
1984 Pontiac 6000 cammed 2.5L Iron Duke
1986 F-150 300 6cyl 5spd.
1994 Crown Vic... Free, bad trans?
Glad you guys know a bit about it, I'm replacing the oil and water pumps, I had to pull the engine cuz my uncle put 5 quarts of oil in it, when it had 3 in it, and it blew every seal in the motor including the head gaskets. I had the heads resurfaced, cleaned, the guides were fine, and new positive valve stem seals installed, and I am using brand new headbolts. Any tips for the rear main seal?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
the guides werent dropped? excellent!
do not scratch the crank when changing the seal......to get the old one out, take a tiny flathead screwdriver and pry out on the seal using the block as leverage, be very carefull that you do not get anywhere near the crank with that screwdriver.......when you go to put the new seal in, pack the inside with grease so the spring in the seal cant pop out.....install the new seal carefully with a small hammer, make sure it is installed evenly
Yeah I was surprised the guides were OK. The heads might have been worked on before I don't know. The cars odo stopped at 68,000 a few years ago, so it might have around 90-100K now. Still pretty low milage.
Oh should I remove that rear main seal housing and install the seal? or just leave it be?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
