Celebrated the 4th of July by working on the car!!!
    well i was bored on saturday so i went to O'reileys and bought the G-ride some goodies. worked on it all day, and best of all, i took pics for y'all...enjoy!!!
ID:	1295778 Click image for larger version
ID:	1295779 Click image for larger version
ID:	1295780 Click image for larger version
ID:	1295781 Click image for larger version
ID:	1295782 Click image for larger version
ID:	1295783 Click image for larger version
ID:	1295784 Click image for larger version
ID:	1295785 Click image for larger version
ID:	1295786 Click image for larger version
ID:	1257341 Click image for larger version
ID:	1257342 Click image for larger version
ID:	1257343 Click image for larger version
ID:	1257344 Click image for larger version
ID:	1257345 Click image for larger version
ID:	1257346 Click image for larger version
ID:	1257347 Click image for larger version
ID:	1257348 Click image for larger version
ID:	1257349 Click image for larger version
    when i took off plug #8, why is it that its so messed up? tons of build up on it and burnt up...? something to worry about or just normal wear and tear? all others looked the same except #8. any thoughts on this?
ID:	1257351 Click image for larger version
ID:	1257352 Click image for larger version
ID:	1257353 Click image for larger version
ID:	1257354 Click image for larger version
ID:	1257355 Click image for larger version
ID:	1257356 Click image for larger version
ID:	1257360 Click image for larger version
ID:	1257357 Click image for larger version
ID:	1257358 Click image for larger version
      been waiting forever to install those ford racing wires...and it looks oh so good!!! agree?
        It's possible the #8 plug had never been changed before. It's not uncommon to find one or both rear plugs on these cars have never been changed since they're a bit of a pain in the hindquarters to remove and install.
          I am loving that signature pic of the car bud. Stunning!
            It looks sort of like the plugs in my car (old engine) after about 3 months... Caused by oil from the leaking valve guide seals... I had the two on the front passeger side that would do that... Not a big problem until it starts puffing smoke when you start it up, or after it has been idling for a while, and you take off, and you look like the mosquito spraying truck... Mine had just started doing that... Another reason for a new engine in my car....
              Both rear plugs on my car had build up similar to that.
              My car burns no oil though (at least not yet anyways).
              Former panther owner
              1981 CV 351 4bbl
              1991 CV 302 EFI
                Mine didn't either... about 1/2 quart between oil changes... Guess it doesn't take much to foul the plugs....
                  I think from what I remember hearing the rear plugs are like that partly because of the way the engine sits tilted slightly back. Regardless, mine were like that as well. It's also nice to know I'm not the only dork that puts all the plugs together numbered and takes photos of them.:smirk:
                  1986 Grand Marquis LS 2 Door
                    pcv screen is clogged up, that's why #7 and #8 get oil deposits on the plugs
                      same here!
                        I had the same problem with the #7 plug on my old 305 sbc. My problem was the valve seals. Not a big problem; you just have to keep an eye on that plug. Now that you got pics of the parts, how about more pics of the whole car:p?
                          If the PCV stuff is in good shape, its the valve seals. The motor tilts backward so the rear cylinders get the most oil running around the guides. If the drainback holes are a bit restricted, and/or the seals are failing thats what you get. Nothing to really be concerned about, though I would make sure the PCV stuff is working as it should.
