so it happened i blew a head gasket. I have a set of e7's laying around that are already machined and ready for install but i wasnt finished collecting all the parts for an HO swap. I figure ill put these heads on my 91 crown vic since i have to take the heads off any way. was kind of wondering how much power i will get from this swap by itself. I will eventually be putting shorty headers and an ho intake on also but i think that will be the extent of it.
blown head gasket
I have no idea how much power the head will give you alone but i must say that just installing a high output upper intake will do you little to no good because your stock egr spacer and throttle body is restricting air going into the upper plenum.~David~
on a stock lopo? heads alone would probably get you about 10hp and you'd probably lose about 10-20ft/lbs torque..Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
are you sure its a blown head gasket? not very common for a head gasket to blow on these motors.
btw.. E7 heads, by themselves make quit a bit of difference.
E7 heads and 3.27 gear in my 88 MGM dropped the 1/4 times almost a full second.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by 88grandmarq View Postare you sure its a blown head gasket? not very common for a head gasket to blow on these motors.
E7 heads and 3.27 gear in my 88 MGM dropped the 1/4 times almost a full second.Builder/Owner of Badass Panther Wagons
Hope you didn't run it long with water in the oil. I've had bad results from doing that. Good luck, let us know how it runs with the new heads.86 Lincoln Town Car (Galactica).
there was no water in the oil till the next day, after it sat overnight it all seeped in. I got the heads on and upper and lower manifold on last night so I will finish tonight. I am going to wait to put the ho upper and throttle body on until i can either buy or find a machine shop to bore out a lopo. for some reason it seems like a bored lopo is hard to come by in California but it is definitely in the works. I wanted to keep my gas mileage so i didn't want to go for a full ho conversion.
