Thermostat/Water Temp Guage
    I was looking for a place to stick a thermostat for an electric fan and I think I might have found it. My '86 CV has the dual heater core pipes and on one end there's a threaded plug. Can I run a thermostat for an electric fan or a water temp guage off of that?
    theres a threaded plug on the end of what, the heater core pipe? Can't say I've ever seen that before, usually the only holes in that are for the ECT, the EGR cooler thing, and the connection to the heater core itself.
      i beleive flex-o-lite has a thermostat that has a probe that gets stuck into the radiator near the upper radiator hose.
      '88 Colony Park, white with wood grain contact paper, K code axle, hose pliers on heater hoses, factory duals, big plans in the future...
      '83 Toyota 4x4, 31x10.50 15, could use a new carb, custom humidifying holes in the roof, mud based paint...
        did someone remove the ect?.....gotta have that for it to run properly.....take pics
        if you want to use a wet sensor for the fan, look for a waterneck with threads tapped for a sensor......might have to do some searching, but i've seen them around
          I think you can use a neck from a Bronco. Also you maybe able to drill and tap one.
            sometimes you can get away with using a t fitting and retaining the ect sensors position as well as adding the fans sensor. if done right it doesnt look bad, done wrong its just ugly.
            1996 Mercury Grand Marquis - duals, PI cams, PI intake, J-Mod, MZT, BOC tune, 3.55s, 18in wheels
            1965 Ford Falcon Ranchero - 5.0 HO T5 Fun Cruiser
            http://www.supermotors.net/users/tmm313
              Sorry guys/glas; crap for memory. There's a sensor plugged into the end of the dual heater pipe. I gotta see if I can find the water temp dummy light and disconnect that to use for the e-fan sensor.
                cheapo autozone replacements have threaded bungs for a sensor, it's cheaper for them to make one waterneck with a plug than two different ones
                  might be a dumb question but do you have a gauge in the car aside from the idiot light? If not don't unhook it. You could put T into the heater line going to the heater and thread it in there.
                  1990 LTD Crown Vic w/ dead 5.0
                  1984 Pontiac 6000 cammed 2.5L Iron Duke
                  1986 F-150 300 6cyl 5spd.
                  1994 Crown Vic... Free, bad trans?
                    Perhaps that'll be that route to take. Thanks for the tip!
                      All of my 351 CVs have had the water necks with extra holes. They are used for some silly sensor, which I removed after the 4bbl swap.
