Hey mangs, was just thinking about putting a auxillary trans cooler on my car and just wnated some input on what kind to get and where to mount it, Where did the police cars mount theres..etc..etc....thanks mangs
Transmission Cooler
i had one on the old vic, mounted in front of the radiator.
ive seen people mount them in between the radiator and condensor as well. im not sure what is best. it seems its a matter of preference as far as i know.1996 Mercury Grand Marquis - duals, PI cams, PI intake, J-Mod, MZT, BOC tune, 3.55s, 18in wheels
In front of the condensor is where the stock cooler mounted. If you're not towing, the smallest one you can find will do fine. The stock police/tow cooler is probably half the size of the smallest thing you'll be able to find.86 Lincoln Town Car (Galactica).
i was looking at mine a while back, i have the normal one in the radiator plus another cooler in front of the condensor which leaks. they run in series and it looks factory installed. i assume it came with the tow package even though i dont have air shocks.'88 Colony Park, white with wood grain contact paper, K code axle, hose pliers on heater hoses, factory duals, big plans in the future...
'83 Toyota 4x4, 31x10.50 15, could use a new carb, custom humidifying holes in the roof, mud based paint...
I have a B&M (I think) tranny cooler mounted in front of my radiator. It would've been in front of the condenser but that's strangely missing from my car. This one is a stacked plate design, which is much more efficient than the fin & tube ones. I'll sell it to you for relatively cheap if you'd like. I won't be needing it anymore...
Originally posted by CheeseSteakJim View PostI won't be needing it anymore...~David~
Originally posted by ss_mini14 View Posti was looking at mine a while back, i have the normal one in the radiator plus another cooler in front of the condensor which leaks. they run in series and it looks factory installed. i assume it came with the tow package even though i dont have air shocks.86 Lincoln Town Car (Galactica).
Originally posted by chitownvic View PostI can't tell that much in the pictures Deuce An A Half but is yours covering the whole front of the radiator..http://secondhandracing.com/Home.aspx
