... alot of little conversion problems today... it will be done tommorow... we just ran out of time today...
Conversion ? what are you converting? what sort of problems?
should be simple and straight forward
2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011 89 Crown Victoria LX HPP -- SOLD 9/2010 88 Grand Marquis LS - The Original -- Totaled 5/2006
I'll never tell... hehehehehehe!!!!
One of the main problems we had was trying to change out the engine mounts... Never could get the passenger side one out... it wasn't that bad, so we eneded up leaving it in the car... But the trans mount and the drivers side got changed out... Another problem was I painted the upper plenum, and the friggen paint WOULD NOT dry! The humidity was so high, that it was still tacky wet two hours later... So we elected to go ahead and close up for the night, instead of trying to mess the paint up trying to mount it... Also, nobody had the gasket that goes on the upper plenum where the intaka "Butty fly" is... had to order one... They sent a master gasket kit with the engine with about 100 gaskets in it.... But no upper intake gasket! So that is supposed to be in today...
Tom
Actually no, it wasn't any harder... we decided to remove the transmission mainly because we could not think of a good way to "suspend" the front of the transmission in the car after the motor was out. also, it makes it easier to line up the trans / motor when it goes back in. it is just easier to lift the transmission up on the jack and get it lined up... side benifit is getting to detail the trans some
I've always used a piece of 2x4 or even a bumper jack with bolts stuck into a couple of bellhousing holes. Not the best option if you have very nice framerails or want to clean and paint them with the engine out, however.
Scott claims you can actually get both mounts out with the suspension in place ... he seemed very confused when he realized I had recently removed my lower control arms with no intention of servicing the suspension at that time. :p
even a wire wheel to the intake will clean up most of the oxidation, thats what i did to the intake on my truck when i put it in, still looks fresh a year later.
Pretty sure a cast intake isn't going to get scratch marks on it since they're generally pretty rough to begin with, unless you have one of them fancy schmancy more-money-than-brains mirror finish intakes.
Oh, and if the wire brush is getting caught in your pants, your pants are too loose. :p
1985 Lincoln Town Car Signature Series But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
True true, but to be honest they were shorts and i was sitting the the item i was wire wheeling.
Yeah, well, uh, you probably should try doing that a different way... :drug:
Wish i had a pic of the truck intake to show how decent it came out. Didnt really leave any scratch marks that i can see. Might be due to the fact i was using an old worn out wire wheel that wasnt really that rigid, so it sort of "conformed" to the shape of the intake a little more smoothly. Looks hella lot better than alum oxidization
I got my big knotted wire wheel on my 4-1/2" electric angle grinder caught in my shirt one day. I was grateful it got tangled in my shirt and not my oversized gut.
Might have successfully removed the shirt if it'd been a name-brand angle grinder.
Yeah, those dumb Chinese angle grinders aren't even good for clothing removal...
