On a friends 89 vic, sometimes it won't shift out of 1st gear. The tranny fluid is full and bright red, and has no funny burnt smell to it. The TV bushing is intact and installed. The car has 114K miles on it and I'm wondering if it needs the TV pressure turned up to make it shift again. Any ideas?
tranny not shifting
tranny not shifting
something broke mang.....might be the end of the road.......get 88grandmarq to hook you up.....he builds aod's and he's not too far from you
He's actually coming up next week to fix Anabelle's transmission and install a shift kit. This is a friend of mine with an 89 crown vic thats doing this, kinda sucks because I just put in a 3G alternator for him.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
I think he means to say this is a different friend with a trans problem, not 88grandmarq who is going to be doing work on his transmission.
No shifting out of first could be too much pressure. See if the lever on the side of the trans moves with the throttle. COuld be it somehow got jammed and its stuck at full pressure.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI think he means to say this is a different friend with a trans problem, not 88grandmarq who is going to be doing work on his transmission.Last edited by 88grandmarq; 06-19-2009, 11:09 AM.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
It could be intermittantly jamming or something. Dunno.86 Lincoln Town Car (Galactica).
got to see this car in person today.
the transmission fluid was over full and dark red.
we drained the converter and filled it with fresh fluid, then bumped up the TV pressure a bit.
seems to drive and shift much better.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
