Do they make plugs or block off plates for the smog tube that goes into the back of the heads? Cause I heard if you do not have the AIR tubes hooked to the cats and the belt for the pump off, it will make your car run bad. So I want to block em off.
smog block off plate
My rod is glowing, my bead is clean, my middle name is acetyleneTags: None
go to a hardware store and buy 2 5/8"-11 X 1" bolts, they will svrew right into the holes in the headshttp://secondhandracing.com/Home.aspx
Neat trick GMGT!
What does putting them on backwards do?89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
I must have missed something someplace! How would cutting the end off of a tube and then turning it around block off the hole? Wouldn't you still have the hole in the tube end plate? Is the end plate offset that much?89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
i think he means turning them backwards so that the smooth outside sits against the blockhttp://secondhandracing.com/Home.aspx
Originally posted by DuceAnAHalfi think he means turning them backwards so that the smooth outside sits against the block
I did jsutin's like that. I think scott does it that way also....1983 Grand Marquis 2Dr Sedan "Mercules"
heres a pic, for those who have never seen the part in question
OK, thanks.
I get it now.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
Re: smog block off plate
Originally posted by MercmarquisDo they make plugs or block off plates for the smog tube that goes into the back of the heads?.
This is what is used in the front of your heads and the accessory bolts are threaded into.
