Do they fit on box (meaning, will they bolt up to the stock H-pipe) CVs, MGMs, and TCs? I found an LSC in the middle of a local JY and it still had the headers on it; no computer though.
I made those HO headers or whatever the shiz they are make with my stock downpipes. Some cutting with a hacksaw and it was done. Had to adjust a few times to get them to stop leaking but it worked.
heads have nothing to do with it. Every Windsor head except the P head takes the same header. The collectors on the HO headers are larger than the stock manifolds, bolt spacing also wider. The flanges can be modded, and it does work if you're not dumb and locate the O2 sensor where it hits the frame.
I want to say I remember someone here making sweet love to their flanges with a grinding bit and getting them to work.
I think that was naters in mn
and last century a guy knocked the top cats out, drilled a hole, welded a 18mm nut to the cats, and bolted em up... I still opted to do the header back exhaust for better performance
