Lincoln LSC Headers
    Lincoln LSC Headers
    Do they fit on box (meaning, will they bolt up to the stock H-pipe) CVs, MGMs, and TCs? I found an LSC in the middle of a local JY and it still had the headers on it; no computer though.
    They will not.
      Different flanges, making them not fit.
        I want to say I remember someone here making sweet love to their flanges with a grinding bit and getting them to work.
          Originally posted by 85crownHPP View Post
          I want to say I remember someone here making sweet love to their flanges.....
          And if I recall correctly, 'Band-Aid' stock prices shot up the very same day....
            lol. In otherwords........it must have leaked like a mofo.
              I made those HO headers or whatever the shiz they are make with my stock downpipes. Some cutting with a hacksaw and it was done. Had to adjust a few times to get them to stop leaking but it worked.
                Lincoln Mark 7 headers are MUSTANG headers. So its the same deal ass with mustang headers.
                  Duh, cuz of the E7 heads. Shoulda though of that. Now that I think of it, why do my BBKs fit on the lopo heads?
                    heads have nothing to do with it. Every Windsor head except the P head takes the same header. The collectors on the HO headers are larger than the stock manifolds, bolt spacing also wider. The flanges can be modded, and it does work if you're not dumb and locate the O2 sensor where it hits the frame.
                      Oh, I gitit now. Could a H-pipe from an LSC be made to work with a box Panther?
                        Again, same as a mustang....
                          I think that was naters in mn
                            That was myself and GL I think. Mine leaked on the one side because I put the O2 sensor in a stupid spot. Would have worked otherwise.
                              and last century a guy knocked the top cats out, drilled a hole, welded a 18mm nut to the cats, and bolted em up... I still opted to do the header back exhaust for better performance
