Converting to Carb
30-40gph, according to Napa Online (I used PN NFPP74028 for a cursory check).
Bowmang, this may mean needing a fuel system upgrade if you go with a bigger cam like we've been PMing about (the 444211 is the cam that seems to be indirectly prompting Pirate to recommend the 120gph mechanical pump mentioned above).2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View Post30-40gph, according to Napa Online (I used PN NFPP74028 for a cursory check).
Not.
Most likely true, especially with your diagnosis regarding my fuel pumps rated at 30gph and 40gph. Maybe he's able to get away with it so far because he's still running a stock Vic cam?2012 Mazda5 Touring | Finally working on the LTD again!
Bowmang, this may mean needing a fuel system upgrade if you go with a bigger cam like we've been PMing about (the 444211 is the cam that seems to be indirectly prompting Pirate to recommend the 120gph mechanical pump mentioned above).Originally posted by Pirate View Post30-40 gph? Well, golly gee, what an excellent idea'r!
Not.
It was in the plans to change the fuel pump when things are getting upgraded, I just didnt feeling like spending the coin for a pump that wasnt needed for the time. But when upgraded, i will still use the Tee method.
But me, id rather have an electric fuel pump, IMO.---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
Originally posted by 1987cp View PostMercmarquis: I had thought that sumping a tank was a fairly involved process ... and potentially dangerous, too, considering it'd involve cutting and welding on a used fuel tank?
Think about it this way, the car has had a complete resto. The bolts for the tank would come out easy, as it was all apart not too long ago.
You are not doing any cutting or welding on the tank, you remove the pickup, and remove the fuel pump. Then you get a short line of 3/8 tube and stick it in place of the fuel pump. Then you can tig weld a fitting to the fuel line. Cap the return or weld another fitting to connect to a return line depending on the type of fuel system you run. Bend new hard line and you'll be on your way.
Originally posted by Mercmarquis View PostInvolved? Not really... 3-5 hours.. Dangerous? No....
And yes, EFI pumps are rated in lph, not gph.86 Lincoln Town Car (Galactica).
I found the Lokar cable; some pieces are missing, so its basically a piece of shit. Fuck my life.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
