i'm in the middle of a tranny fluid change and this was in the bottom of my pan. if you could help me asap and let me know what it is and where it goes it would be much appreciated.
[IMG][/IMG]
[IMG][/IMG]
they put that in the dipstick tube hole when the car is built.......dipstick tube goes in that bobber looking thing stays in the pan till the fluid is changed
haha you would think there could be a few words saying what it is haha... like the "Do Not Eat" little moisture sucking packets in your beef jerky bags. oh, and my refill after draining the converter and pan was almost 11 quarts out of the 12.3 dry capacity so i guess the draining went pretty good. about a good 2/3 of the fluid was out of the converter drain.
What Thain said, there is surprising amount of fluid in the valve body, and particularly above the accumulator pistons - it just sits there, waiting to assassinate you by leaking in your eyes when you attempt a shift kit install. Guess how I learned that...
