The right cat gets cherry hot. I thought it could be a miss fire dumping fuel into the exhuast than making it burn cherry hot, than I thought maybe a clogged cat it also is dogging of the line bad... Whats your opions need your help here guys idk which way to turn.
Ok I got the dual exhuast on the vic but
Glowing converter is a rich mixture, and/or a majorly clogged converter. If the converter broke apart, it could be clogging up the exhaust.86 Lincoln Town Car (Galactica).
well I did remove my smog equipment could that possibly cause the problem... also what could make it run so rich check the wires and connections seem to be oksigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
I know the smog pump, pumps air into the cats and thus cools it a bit. But i dont know if removing the smog pump will result in an overheated cat.~David~
used cat or new cat?
Just gut it.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
its used i use to have them on my wagon but i changed the exhuast from there to this car maybe 500 miles on them if thatsigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
They didn't get damaged in any way did they? If the brick inside cracked loose, it will jam up the works.
Has your fuel economy majorly tanked lately? Any black smoke or funny idling? usually that would indicate a mixture problem. If none of that has changed, I'd have to think converter problem
removing the smog pump won't cause problems. I've been running without one for years now, never had a glowing converter.86 Lincoln Town Car (Galactica).
The gas mileage has been a lower than usual i thought it was due to leaking exhaust I had before. But I dont think they are damaged. But I think I gunna replace them anyway I have 2 new ones around. But I dont want to put them on if its running bad.sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Fix the problem first. Pull the plugs on that side and see if one is black. If it is, I'll bet you've got a bad injector. Could also be a bad vacuum leak causing it to do that.86 Lincoln Town Car (Galactica).
well I was correct it was miss firing and dumpin fuel into the exhuast spark plug wires got switch 3 and 2 whoops ... car runs real nice now realy smooth and i still think i m guna put high flow cats on the car still. Not sure what midas put on the h pipe orignaly they dont sound like high flows. still want more power and sound lolsigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Its a stock motor, there is only so much you're goiung to get out of it. Having the converters swapped probably won't do much for you. Gears will help a lot more if you've got a 2.73 rear.86 Lincoln Town Car (Galactica).
yea, unless youve got enough motor to move exhaust efficiently out its not going to help. you need to keep a good exhaust velocity otherwise you will lose torque.
the exhaust setup you have right now is good for a stock motor. id leave the exhaust alone until you do further upgrades to the motor.
