Engine cutting out while braking or cornering
Right, that's the 6588 I was commenting on above ... the question being, is that enough higher flowing than stock to make a difference? 120 gph sounds small, but that may be because I usually only hear flow rates quoted for super-high-capacity EFI pumps.2012 Mazda5 Touring | Finally working on the LTD again!
Correction on above: I got smart and looked at some of the other pumps Summit lists, and noticed that a lot of the other under-$100 ones are only 80 gph. Even the Edelbrock Victor Series is only 130gph! So I guess I need to see whether I can score one of those Carter pumps locally for cheap or if it has to wait till I piece together another Summit order.
EDIT: I found flow rates listed at NAPAonline.com.
For a 289-4V Mustang it lists Pressure Rating: 5 lb - 7 lb, Gallons Per Hour: 23
And for '79 LTD with 351W-2V: 6.5 lb - 9 lb, Gallons Per Hour: 40
And.... for the '87 "high output" return-style pump: 6.5 lb - 8 lb, Gallons Per Hour: 30!!!!
Dang!!!
Last edited by 1987cp; 05-21-2009, 10:29 AM.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostCorrection on above: I got smart and looked at some of the other pumps Summit lists, and noticed that a lot of the other under-$100 ones are only 80 gph. Even the Edelbrock Victor Series is only 130gph! So I guess I need to see whether I can score one of those Carter pumps locally for cheap or if it has to wait till I piece together another Summit order.
Dang!!!
Oddly enough, a lot of guys use the Holley 'Red' fuel pump as a cheaper electric pump, as it pushes about 4-5 psi, and works pretty good for mild Chevy 350's without a regulator.Last edited by Guest; 05-21-2009, 12:10 PM.
With a mechanical pump it should not.1989 Grand Marquis LS
Originally posted by Grandpaslincoln View PostDoes the vic have an inertia switch for the fuel pump? Another thing to look at.
Going electrical has crossed my mind, but staying mechanical would probably be a good deal simpler and might even be cheaper. I'm not enthused about the idea of having to run a regulator, but I'll try to figure out a system that will work for the least effort and $$$. (This was the car that I had intended to do absolutely nothing to and just drive it!)
Pirate, another question about mechanical pumps, if they're a nonreturn style and run without a regulator, what provisions do they have so that they don't just sit there and flood the engine?
Also, I saw something about this pump having a "vapor return" provision; I had assumed it returned unused liquid fuel to the tank like a normal regulator.Last edited by 1987cp; 05-21-2009, 08:03 PM.2012 Mazda5 Touring | Finally working on the LTD again!
So far as a regulator goes....I'd use one and a pressure gauge in addition, as I don't like running anything past 4.5-5 psi to a carb, as anything above that is hard on the needle and seat assembly.
:lol:
Return-style regulators are EXPENSIVE .... wonder if I should consider eliminating the return line altogether? I had assumed it would make things happier, but I know most mechanical-pump systems don't use one ... deadhead regulators seem to be a lot cheaper, starting at about $20 at Summit ( http://store.summitracing.com/partde...5&autoview=sku ), so that wouldn't be too awful combined with the $25 Carter fuel pump and a cheap gauge to leave underhood. Something like this, maybe? http://store.summitracing.com/partde...5&autoview=sku Unless one can easily buy cheap gauges that read up to only like 8 or 9 psi ....2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostRight, that's the 6588 I was commenting on above ... the question being, is that enough higher flowing than stock to make a difference? 120 gph sounds small, but that may be because I usually only hear flow rates quoted for super-high-capacity EFI pumps.86 Lincoln Town Car (Galactica).
Here you go 500 gph will that be enough?
1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
